Memory problem?
Dexmaus
I have this computer at home, its a P4 2.26 with MSI board, i recently put my 9800 pro in it, and when i play BattleField: Vietnam, it reboots by itself a lot, i mean everytime i get in it will reboot by itself, i just had a fresh installation of windows XP, it still does the samething, i'm wondering what could be the problem? i have only 256ram on this pc, it seems it loads the game pretty shitty and the HD's noise is loud.
Disable automatic reboots to see if it gives you a Blue Screen. If not, maybe your computer is nicely trying to tell you, don't even think of playing this game without at a bare bare minimum 512 MB of memory. The HDD noise is loud because your paging most of the game files to virtual memory, because 256 isn't going to cut it for that game.
I've gotten the Blue screen twice now while playing BF Vietnam....i still trying to figure out what's causing it.
If you actually do get a blue screen, it's usually very simple to look it up and find out what's wrong.
