Memory Problem?
adamkp83
I've recently built a computer, and I'm using GEIL RAM 512MBx2sticks...DDR400 CL=2.5-8-4-4 stock.
No tweaks or OC'ing going on here, either.
I have been receiving Pagefaults (BSOD-like) and forcing me to reboot/shutdown. I've taken one stick out and have been running for half an hour with no problems so far. Are pagefaults (core/mem dumps) indicative of failing ram, or could it be other hardware problems? I've never run into this before so I'm at a loss. Any help would be greatly appreciated.
Right now I'm running on one stick in my DIMM Slot 1.
I am using a DFI Lanparty NF4-D/Nvidia 6800GS/Athlon XP 64b 3000+ ... If I need to post more information, let me know... Thanks again!!
-Adam
move that to slot 2.. the orange slot furthest away from the cpu. have you tried running anything like memtest or superPI 32m?
No, I will google that application and run it. I will try moving to the 2 slot afterwards.
Wish me luck!
Thanks!
-Adam
Looks like it might be a virus problem - already - only d/led four things but I never immediately patched xp. I received a pop-up spam window advertising some windows cleaning product since it claimed my registry was corrupt and I had a virus. A friend suggested blaster, matters not really. Going to try and create a xp cd with sp2 slipstreamed into it... Thanks for the previous suggestions, and I hope that it's a virus - not a hardware issue. Ciao
-Adam
Okay...another thing I've tried.. weird...
Both sticks in. First test DIMM slots 2/4 for dual channel operation... page fault, random and when I ran memtest.
Second test DIMM slots 1/3 same.. same.. same results :(
But, each stick passed seperately on memtest to between 4000-5000% complete w/0 errors.
Weird?
TIA
-Adam
i had some similar issues with my dfi board and g.skill ram
the dfi mobo defaults to some pretty aggressive settings for memory.
if your memory is low latency, aka 2, 2, 2 timeings, run the memory in slots 1, and 3, if its cas 2.5 or higher run it in slots 2, and 4.
then manually configure your mem settings in the bios, should resolve your bsods.
g.skill is pretty good about posting recomended timeings for the dfi boards on their page if you go lookup the ram you have.
i find that orange slots work best for me no matter what it is i'm using :p
The CL timings you have listed in your first post, are they controlled via the SPD in the BIOS? I had a similar issue with a set of Mushkin BluePack on an MSI board. Turned out that the SPD timings the BIOS set my ram to were a bit too aggressive. I dropped the CAS timing back to what the rated settings were per the manufactuer and bingo, my BSOD's went away.
-E
Oki, back from the weekends festivities, lol. Those timings were from the label on my sticks. I don't know what those acronyms you are using means. I will check the BIOS and see what the settings are, I will make it match....if I can. At least lax it a bit if it's aggressive. Thanks for the comments guys.
-Adam
P.S. If it runs with two sticks it's sooo slow seems like I'm running 256MB instead of 1GB. I'll post more later if I can make any headway..
much love, word! ;)
-Adam
Would settings 2.5-4-4-8 cause pagefaults when the factory settings (that I haven't messed with) are set as 2.5-8-4-4.. I don't know if this is considered too aggressive - or where to change it at, lol.
-Adam
From what I've read the last number difference - being higher than the factory - allowing more time to end a row and start another row - shouldn't be that big of a deal, being more laxed and all.
The second setting being half of what the factory has set, seems like it could be a problem, since it's only allowing half the time for the ram to read/write/refresh... sounds like that could cause some problems.
Am I understanding DRAM properly and what all those settings mean..?
Thanks in advance,
-Adam
your best bet is to run everything at factory settings first, make sure its good and stable, then tweak up the mhz to where you want, then tweak down your timeings as far as you can. takes alot of patience..
Adam,
Anytime you cut the refresh rate down you limit the DRAM's ability to recover from an error when writing to memory, so a BSOD would be the OS's natural behavior in such an event. Drop your timings in BIOS back to stock timings ignoring the value being set by default. Run MEMTEST for a couple of hours to verify the timings did the trick.
-E
