I've just started overclocking the memory (Corsair 4400C25PT matched pair) on my new system so I can find it's limits. Have throttled back the cpu to 8xFSB and raised the FSB to 225Mhz. The timings I'm running right now are 2-2-2-10 (memtest86 v1.51 reports tRAS 10 as optimal for mem bandwidth).
In order to get, stably, past 223Mhz FSB I conservatively raised DIMM voltage to 2.8V. All other voltages are default. Tonight, when I get home from work, I'll continue raising FSB until I become unstable again, at which point I expect to have to raise DIMM voltages again. Can someone give me an indicator of what is regarded as a "mainstream" memory overclock voltage? And is there a voltage I shouldn't go beyond?
Finally, when memtest86 reports errors, is there a way of recognising which memory timings I need to raise in order to fix things?
All help greatly appreciated
