Memory or motherboard?
Tullphan
I'm working on a PC for a friend. It gives me a memory management error (blue screen). It has a fresh install of windows & only video drivers (from nVidia), cpu-z, p95, & core temp are installed.
He has an EVGA X58 SLI motherboard, 2x8800GTS in SLI. The memory he's using is G.Skill F3-12800CL7D-4GBRM. He has 12GB total, but they're 3 sets of 2x4GB kits.
I installed all 6 sticks at first & did fine. Ran P95 for 18 hours w/no problem (small FFT's after running 7 hours of large FFT's), 20 passes w/Intel Burn Test, an hour & a half of Furmark. No problems. I rebooted, the first screen (where it shows the CPU, HDD's, DVD/CD's, etc) showed 8GB ram & got into a constant reboot. I booted into Memtest86+ & as soon as it started it showed error after error. I quit, shut down, took out 3 sticks, restarted & all it did was run the fans. I moved those 3 sticks to the next slots & it booted, went into Memtest & again, errors. I took out those 3 sticks & put in the other 3, turned it on & just the fans running. I moved them to the other 3 slots, powered on & again to Memtest. This time it ran for hours w/no issues.
My friend swears up & down the memory is good. He told me he can fill up 4 of the 6 slots & it runs like a champ. I explained to him that it's set up for either 3 or six sticks. He told me that a tech from EVGA told him that he (the tech) would almost bet the problem lies with a bent pin under the CPU. Myself, I think it's the ram since 3 sticks booted & the other 3 brought errors.
Thoughts?
