The memory being referred to is that listed in the first rig in my signature: 2x512MB Mushkin Level II PC3500... the old BH-5 stuff.
So, I'm going along playing WoW, and from time to time I get various errors about access violations. Checking the WoW forums, they like to blame it on the user's hardware, especially memory. I download Memtest86 3.2, Memtest86+ 1.40 and the Windows Memory Diagnostic, run them all and encounter no errors during testing.
Then, I decide to let Prime95 run for a while (on WinXP). The first time I ran it, and I had reinstalled Windows only a day or two earlier, I put it in "Blend" mode, and had somewhere between 512 and 1024MB of virtual memory as well. That test ran for only 2 hours.
Next, I disabled the paging file and tried again. Prime95 would not run the Blend test without virtual memory, so I settled for the Large, In-Place FFTs test. This ran for only 41 minutes before failing.
Today, I had virtual memory set at 768MB, no more no less... started Prime and left for work. I think I'd be more surprised if it were still running when I got home than not.
Any idea what could be the reason for it to be passing the memory diagnostics but failing Prime? Would lowering the latencies possibly help some? Thanks.
