Memory Issues/Questions
CalvinGT
I am cross posting this part of a message I wrote in a thread in the OC forum to see if I can get you memory gurus to give me some specific tips on what might have happened to my RAM and how not to screw it up completely again. Mods, if this is not acceptable please LMK.
So, last night I got home late and started playing some Quake 4 and other random things. Eventually I got a hard lock, so I think "shit not again" and reboot and run orthos. Stable for about 45 minutes, so I am thinking-this is ridiculous, its time to run Memtest. Without changing anything, I ran the newest version of Memtest. Bam. Wow. 9 errors in one pass.
So i went ahead and reset the CPU FSB to standard 9x266 and defaulted all the voltages and reboot. Whoa. Memtest went crazy with errors. I then decided to go ahead and reset everything in the bios and run it again. This time I got through one pass with no errors-I grew suspicious and went into the bios and looked at the settings. Sure enough, it had defaulted my RAM (http://www.newegg.com/Product/Product.aspx?Item=N82E16820146673) to 5-5-5-18, which is ok I guess except the RAM is rated to run at 4-5-4-11! So, unhappy with this I manually reset the timings in the bios, first by setting it to expert and entering the values myself, the second time by enabling the SLI memory feature (which defaulted the RAM to the correct values).
After doing each of these things I ran memtest. Each time I got 9 errors in one pass. I have not had time to confirm that the RAM gets no errors at 5-5-5-18, but I think its fair to say at this point that my RAM is dead/bad/something, right? I am very frustrated right now. Love my new build, love the speed of my computer and my snazzy case, but I have been a fastidiously careful overclocker, have NEVER overclocked the RAM, and ended up with dead sticks ( I also got my first BSOD last night at standard CPU FSB @ 4-5-4-11).
Any thoughts here? Please tell me its not my mobo or something like that. Please! I guess I am going to start the RMA process and see if I can get a gig of RAM cheap from someone to tide me over.
A few quick general questions:
- For a regular overclock (something like 3.2 on 6600) what is the customary procedure in terms of RAM timings. Did I make a mistake having the RAM on expert and forcing 4-5-4-11 at 3.2 (2.2v)? Was that what caused my issues? I never figured the RAM wouldn't run that speed when I left it at the default 400mhz, and it certainly had no issues for a while. If that is where I made my error I want to at least learn from my mistake.
- What is the appropriate "default" setting for the motherboard to make it find your RAM's correct timing without you having to manually enter it?
