Atwooooood
- Oct 28, 2009
So I have had an ongoing memory problem with my system for months now. At the current moment I have two 1 gig sticks and one 2 gig stick. My other 2 gig stick is bad. I am trying to run 4 gigs by putting the 1 gig sticks in dual channel mode in the primary slots then tack on the 2 gig stick in the first B slot.
FYI the sticks are all the same, Corsair Dominator, the only difference is the size. My system wont even post in the above mentioned configuration unless I jack up the NB voltage but then it just blue screens while loading the OS.
When I put a 1 gig stick and the 2 gig stick in dual channel then tack on the other 1 gig stick in the B slot, it boots fine. Is there any difference in running it in this configuration and is there a reason it works in the 2nd configuration but not the first?
