Memory for Biostar tforce 965pt
DoodieBody
I was just wondering if anybody has had an recent luck with pairing memory with the tforce 965pt mobo for a decent 6300 overclock.
I recently purchased that setup, only to discover that some memory doesn't play nice with it and craps out at exactly 375 FSB. Blah. I'm just looking for some decent memory that has had luck in OCing with that board. I'm not going crazy with it, 2.8GHz-3.2GHz is all I'm really looking for. Just need something that's compatible.
The following two sets of RAM work with the P965PT.
OCZ Platinum Rev2 DDR2-800 2x1GB (OCZ2P800R22GK)
and
A-Data DDR2-800 2x512MB (ADQVE1908K)
I've tested both of these in my Biostar P965PT. The sticks of OCZ Platinum that Polygon on the Rebels Haven forums had are a different model. Both of the above sticks clock up to 450Mhz using 2.2v @ 5-5-5-15 timings. The RAM can most likely go higher but this motherboard doesn't seem to want to get past 460. Some have luck getting them up to 500. It's kind of luck of the draw as some DS3 owners are also getting up around 500Mhz FSB.
The A-Data chips are made by Elpida and the OCZ are Promos.
Just as an update, I purchased the 2gig kit version of the A-Data memory suggested.
I'm currently running it at 2.9GHz (415FSB) no problems. Dual 32M Super Pi stable, and has been running Prime95 for an hour now. I'm sure it can go higher, but I'm not greedy.
I'm a happy boy. Thanks for the tips!
cool... i used some teamgroup d9 ram.. 3-4-4-8 @ 667 ram got it 4-4-4-8 @ 999 on my old setup. i miss that thing. stupid new asus p5b deluxe aint workin right so i'm stuck using awesome parts on my ecs mobo. grrr... no agp vidcard. doh! yah... i'm not very happy. nice board though. i'm considering buying another biostar 965pt board, but i went along with a p5n-e instead. you got yourself a good thing goin there if you your adata ram is d9. glad you're happy with it.
