I know that this athlon 64 only supports "single channel memory" as opposed to the dual channel that the FX series supports, care to help me elaborate on the difference?
Originally posted by randytong
I was actually looking at these:
http://www.newegg.com/app/ViewProdu...145-415&catalog=147&manufactory=BROWSE&depa=0
I know that this athlon 64 only supports "single channel memory" as opposed to the dual channel that the FX series supports, care to help me elaborate on the difference? thanks again![]()
Originally posted by laws_69
That Asus board will post with almost any DDR ram. But keeping the XP or 2k hive happy is hard to do on that Asus...my CorsairXMS3200 isn't like...the SPD timings are read wrong. Make sure with the AMD64 KT800 boards to MANUALLY set your timings even if you don't want to overclock. I've been stable and the hive hasn't pooped since I manually set it all.
Was he having hive failure all the time?
I knew it was memory when I got a hive failure on the first reboot of Win2k installation (the one before you actually get to use the desktop).
