Originally posted by burningrave101
*On a side note i would just like to say that Intel platforms benefit from the tight timings the same as AMD machines do and that there is no benefit in running PC4000+ over PC3500 with tight timings on an 865/875 chipset board. On the other hand, on an 848 chipset board without dual channel abilities, the huge increase in bandwidth benefits more. In order to see the benefits of low latency memory over high speed bandwidth you have to have dual channel enabled and run with aggresive timings such as 2-2-2-6 or 2-2-2-5.
Noted...and added more Intel info.
