Nov 6, 2005 #1 E EMBEN27 n00b Joined Sep 21, 2005 Messages 18 What do you guys think of this?? Only 7 bucks... http://www.ewiz.com/detail.php?name=CA-MMC-B
Nov 6, 2005 #2 X xdkimx Limp Gawd Joined Jul 17, 2005 Messages 443 for $7 id take that if my ram was running too hot hm but it looks like it wont fit with a xp90 heatsink
Nov 6, 2005 #3 D DarkBahamut Gawd Joined Mar 18, 2005 Messages 551 Seems pretty useless to me. 6.7 CFM? Why even bother. The only chips that *need* air cooling are the UTT/BBH-5 stuff that use high voltage, and then those recommend 15-20 CFM, so even then this would be useless.
Nov 6, 2005 #4 O Oline61 Gawd Joined Aug 8, 2005 Messages 869 Is there anyway to water cool RAM? A heat spreader with water flowing through it for instance...
Nov 6, 2005 #5 S Skin Limp Gawd Joined Apr 21, 2005 Messages 471 There are a few, but performance is negligible at best, even with overclocking. No more than a 2% gain or so over a fan blowing on it.
