Memory cooler?
tarheel112
Does one really need one? How much does it help? I am not ocing my ram nore overvolting. I can see a use when water cooling but would it help for air?
I'm sure there may be instances where a cooler is needed, but I would say for the most part, its unnecessary.
I run both overclocked and overvolted and my ram never gets more than just mildly warm.
My CPU and GPU are watercooled, but I have a 120mm fan in the front blowing across my hard drives and a 120mm fan in the rear exhausting air out the back , thus passing over my ram on its way thru...
If your not overclocking or over volting the ram, its certainly not needed .
Maybe, if the chips came from the module maker with heatsinks already on them because, ironically, heatsinks usually indicate inferior chips that failed factory tests and were dumped onto the secondary market. Other indications the chips are second-rate are the lack of any chip manufacturer's logo or part number or a higher than normal voltage rating.
Water cooling RAM is just for show.
I have my 920 @ 4.2 and I dont have anything more the passive air cooling my RAM.
so no, it isn't needed and will not help... but of course it wouldn't hurt either ;)
If you are not going to overclock,... don't waste your time or money trying to cool the RAM, for that matter the stock cooler is more then enough for the CPU and GPU even.
I just installed a Gskill mem fan (12 bucks on newegg) and it lowered my NB temps ~3-4c on average. I will say it is huge, It looks like it could fit over 5 Dimm slots, so centered on 4 slots it hangs over maybe 5mm or so on each side. I could see problems if you had a huge CPU heatsink but if you are using something small like an H50 there is plenty of room.
