memory controller failure? evga 680i
unhap
So I've never seen a memory controller fail before, so I'm not sure if the issue is my ram or the mobo.
The mobo is an evga 680i
When I stick 4, 1gb sticks in (every slot full) memtest86 fails and I get stability issues in windows.
When I stick 3 sticks in memtest passes without error and the system is completely stable.
I tried swapping the sticks around and as far as I can tell that doesn't make a lick of difference.
If this is the mobo, does anyone know if I can still get a replacement from evga? This thing is a couple years old now, I got it when the 680 line was fairly new.
yeah it's a fairly common issue. The memory controller failure usually gives you a C1 error on the post code.
I ended up going through 4 evga 680is (3 memory controller issue failures, 1 which sata problems), and then they ended up giving me a 790i ultra by mistake that was mislabeled as a 780i. If they don't have any 680i's, they'll give you a 780i instead. I'm sure they still have some nvidia boards which are 775 socket.
I have never had to return anything to evga (or anyone for that matter...i've been lucky..) before. Do I have to send my mobo back first? Am I without a computer for a week?
Are you running the MCH at stock voltage?
When I was running a 680i with 4 sticks, I needed to raise he MCH voltage to make it stable.
Does it help if you switch to manual memory configuration and slow all the memory timings? If the BIOS doesn't allow different timings, you'll have to edit the SPD of each module. Actually you want to edit only one module per channel, not all four modules, because then you can be stuck with a dead system.
Are you using good quality DDR2 memory, that is, something specified for 1.80 volts, lacks heatsinks, and lets you easily identify the companies that diffused the chips?
