Memory Compatibilty Question
Noxxville7
I'm currently using a set of this http://www.canadacomputers.com/product_info.php?cPath=24_311_313_622&item_id=024196
Unfortunately I'm now running into an issue where I'm running short on memory (often running at >95% memory usage) and am feeling a need to pick up another set to bump it up to 8GB.
That memory is now special order which I'd rather not deal with if it can be avoided (I'd have to send it to my parents house 4 hours away and pick it up another time) so I'm wondering if this would be compatible with my current set http://www.canadacomputers.com/product_info.php?cPath=24_311_313_622&item_id=018157
As far as I know they're the same memory, just a different heat sink. I looked up the data sheet on Kingston's website and they run the same timings at the same voltage and everything.
Appreciate any insight anyone can provide.
