memory bandwidth only effects bigadv WU's and its effects are huge. it has very little to no effect on standard SMP and has absolutely zero effect with video memory on the GPU3 client. GPU2 there is a slight advantage.. 100-125ppd at the most.
Are you referring to memory bandwidth gained by DDR3 bit width, frequency, or both, or neither?
Can memory bandwidth also be gained from going to dual channel or triple channel memory?
All DDR3 is 64-bit.Does a memory interface of DDR3 64bit vs 128bit effect folding in any way?
memory bandwidth only effects bigadv WU's and its effects are huge. it has very little to no effect on standard SMP .
Thanks for the info. I got in on the GT430 for $5 after rebate deal and might get it folding.
