I've noticed that my SQL servers have a high Memory Balloon rate but the memory swap is very low. Can I safely assume, that this is due to the nature of SQL servers as it tries to grab as memory as you allocate it?
You shouldn't be ballooning unless the host is overcommitted on memory and is having to go through reclamation techniques outside of just TPS. Memory swap is a last resort the host will take to reclaim memory and you really, never want to see that. Your partially correct though in you assumption about why you might see ballooning more on a SQL server compared to others. ESX(i) will try and reclaim memory based on the idle memory tax, so VMs with much more static non changing memory are going to balloon more.
SQL will use whatever memory it thinks it has for caching which may cause the vSphere box to run low sooner than it should which is why it's using the balloon driver. Normal expected behavior. Since it's just caching on the SQL box it'll give that memory back when requested..which is why you see high ballooning but no real swapping. If you want to guarantee the SQL box can cache a lot you reserve the memory.
