Memory and Bus Speed
Hi,
I have an old Dell Inspiron 600m. Originally it came with 512 MB RAM (2 x 256MB), running at 266 MHz (PC2100).
I bought a 1 GB DIMM, PC2700 333MHz to increase the RAM.
I know that if I mix the DIMMS, the speed of the RAM will run at the slower speed, in this case 266 MHz.
But, if I just had the 1GB module installed, shouldn't the RAM run at 333MHz? I looked in the BIOS and it still shows it running only at 266MHz.
My FSB is shown at 400MHz, if that makes any difference.
Thanks.
Your FSB and Memory bus can be at different speeds. FSB is only from the CPU to the ram. The ram can have a different speed itself. Your motherboard may only support 266 mhz memory, or you may need to manually change it. Try resetting the bios to defaults.
BTW, you won't notice a difference between 266 and 333, so don't feel that you're missing out on anything.
