MegaRaid SATA 150-4 Drive Problem
I have a MegaRaid SATA 150-4 with 4 Samsung HD154UI drives in a RAID 5 configuration. It had been in service about 6 months. The RAID card reported 1 drive had failed. I ran SeaTools on the drive, it came out clean. When I try to rebuild the drive into the array, I get a drive is a different size error in the Power Console. In the CTRL-M config, I get not responding. I believe the card might be reading a partition error. I don't think I have ever tried to format the drive under NTFS. The computer is using XP as an OS.
Is there a utility to reset the drive back to a unformatted state?
Thanks
Have you verified that after plugging the drive back in the machine that has the raid card that the drive spun up?
No I have not.
The computer will be busy for a few days rebuilding the new drive. I will check that soon as it is completed.
Rebuilding the new drive? Confused, you mean you bought a 5th drive or is it now accepting the old drive.
Thanks
assuming from within windows, or otherwise at a windows command prompt....
in command prompt, type "diskpart"
type "list disk"
select the drive that you want to erase ("select disk x" where x = drive number)
*make sure this is the drive you want to erase*
type "clean" (if you want to zero all sectors on the disk, type "clean all")
your computer will now see this drive as if it were brand new unformatted.
