megaraid 9240 hardware?
sdadept
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118128
this is more of their entry level card, but it's $304. Is this a 'true hardware' raid solution? I am buying a 2u case that has two 8087 ports for two rows of hot swap x4 drive bays. I want to put 6 sata hard drives in those port and run raid 5 by connecting two 8087 cables from the card to them. However, due to the fact that several vm's will be running on this, the raid performance needs to be really nice. I'll spend more if I have to, but I don't want to go crazy. :) Any advice is appreciated.
If you want hardware RAID, you're looking at the 9260. The 9240 should still offer better performance than the usual on-board RAID however.
Meta, I was considering that one. I saw someone post that 3ware drivers weren't being kept updated so I worry a bit about that. I might just spend the extra to get the LSI card and keep it for the long term.
