- Aug 10, 2009
Hello all
I am in the process of getting a stepping stone upgrade. Instead of a complete overhaul I am getting a new Mobo, CPU, RAM and heatsink. The Megahalems I plan on getting will be fitted with a push/pull config with 2 120x38mm fans. Now, I am getting either a) P6T Deluxe v2 or b)EVGA classified 760 for my mobo and the RAM are these http://www.newegg.com/Product/Product.aspx?Item=N82E16820231254&cm_re=gskill-_-20-231-254-_-Product Gskill tridents.
Will the heatsink fit with the 120x38mm fans without running into the RAM stick in the slot furthest to the left? Also all these parts are going into my Lian Li pc-x500
