Alright, I was thinking about this and i see no reason why one of you elites can't try it out on a Graphics card or CPU:
It is simple:
Link the main heatsink of either or both to the Main Case.
Case is made of Metal, the thin sheets ensure excellent head dissipation, it has massive surface area, it has fans all over the place, and its grounded. The only downside I can think of is the main contact will have to be big and solid so as to transfer the heat to the case adequately from the card/CPU. The case effectively becomes a massive heatsink.
I cant believe noone has thought of doing this before... or maybe someone has?
Can somone try this and let the rest of us know how it performs? Obviously the actual performance will be case dependent, but still, a rougn idea is good.
--RAGEdemon
It is simple:
--RAGEdemon
