Medium hot: lapping kit special - ArcticSilver 5
insulglass
Note: This post was approved from a "vendor" standpoint by a moderator with the request of entering "medium hot" in the title line.
Here's what I have today: I had a buyer unexpectedly back out this morning on a large order of AS5, so I have excess inventory.
I normally sell my premium lapping kits (with Ceramique) for $13, with an option of $3 additional for an upgrade to AS5. Today only, I'll make the upgrade for free.
The kit will include:
9 quarter sheets of lapping paper (400, 600, 800, 1000, and micron graded 40, 25, 20, 15, and 10)
1 sheet of double strength glass
1 small tube of Arctic Silver 5 (instead of Ceramique)
comprehensive instructions
$13 plus $4 shipping via Priority Mail (my cost)
***note: must mention that this deal was seen on HardForum***
View feedback at heatware and ebay under "insulglass", I have sold quite a
few lapping kits before to HardForum members. Please Paypal me directly instead of going through my site checkout, this is one way I can help determine monthly standard traffic that is and is not forum-driven.
Many thanks to HardForum members and others who have used, reviewed, and provided feedback for my products. Thanks everyone!
Dave Brown
email and paypal to: insulglass@easypckits.com
www.easypckits.com
Looks like a great deal considering all one gets. AS5 is such a pain to buy alone cause it usually seems overpriced to begin with and then you have to tack on shipping.
So this is basically to clean the bottom of your CPU of the stock rubber crap correct? :confused:
Um... not quite. You can use a razor for that. Lapping comes afterwards.
Lapping will get your heat sink flatter and smoother so that the mating contact to your CPU is to much tighter tolerances - thus increasing the thermal transfer efficiency. Using a lapping kit will typically drop temps by several deg C (YMMV, but average is 2.5 to 3.5C drop). This can make a significant difference when pushing the overclocking limits.
Dave
PS - I will add a day to this deal - the other main forum I post to has had some server problems, so I'll go a day extra.
how many processors will a kit work on? just one?
Sorry for being such a n00b. Never heard of a lapping kit before.
It depends on several factors:
- how much water you use (you can't get too much!)
- you personal technique and motion
- microbevelling your heat sink to prevent snagging
- letting the paper do the work instead of bearing down too hard
- going through all grit levels in succession
- generally following directions provided
- taking care of the paper by rinsing wella nd often, and drying thoroughly when done
- etc., using good common sense :)
It is not unheard of for people to lap several sinks with this kit, but as always, "your mileage may vary." I would say that most people are able to get 2-3 CPU sink lappings out of a kit, maybe more for smaller sinks by using the paper edges.
Hope this helps -
Dave
Would you post a link you know of that provides additional info on lapping for the n00bs out there like me? Would just like to read a bit more about it and maybe see some benches.
Before anyone out there gets a wild hair and tells me to Google it.....insulglass is the expert here and I would like to hear what site he recommends. :cool:
Gunz, I'd be glad to help.
I might suggest first, though, that you go here:
http://www.easypckits.com/faq/faq.pdf
This is the FAQ from my website that will explain probably 80% of your questions. Once you've had a chance to read this info, post specific questions and I'll do my best. Fair enough? :)
If you are looking for reviews... you will find a mixed bag if you Google it. I have linked a number of reviews on my site at http://www.easypckits.com/reviews/ . As far as I know, I probably have more depth of reviews than any other lapping kit/system provider - some of the reviews are very detailed in "how-to" others are more focused on the bottom line. I think you'll find the TWEAKERS article to be a good mixture of both and I find it to be a pleasant read.
Dave
