MediaSonic raid enclosure - raid required?
null
I'm looking at this MediaSonic 4 bay raid enclosure:
http://www.amazon.com/Mediasonic-HFR2-SU3S2-PRORAID-Drive-Enclosure/dp/B003YFHEAC
For anyone that has this, can you tell me if raid is required?
I won't want to run raid initially, I'd prefer my machine to see each of the 4 disks independently. E.g. Music (disk 1), Video (disk 2), Photos (disk 3), Work (disk 4).
Specs cite that the enclosure supports "Single Mode", but I'm not sure what that means, exactly.
Any help appreciated.
Thanks guys.
I'm aware of the ProBox. I'm going move to raid in the near future, but not before buying this enclosure, that's why I want to make sure ProRaid can be run in single mode until I make the move to raid.
I'm using one of those for ZFS. I am using the eSATA port and an eSATA card with Port Multiplication. It mounts all 4 drives separate, which allows ZFS to take over and do its magic.
I will probably never use the USB....it seems based on reviews that the USB aspect is questionable.
EDIT: I have the $100 from Amazon. Zero problems over the last 6 months.
Are you able to monitor SMART on each drive? Just curious, because of the port multiplier.
I don't know if the pro-raid version of the enclosure acts differently, but the pro-box version of it will provide individual drive statistics for smart, temp, etc when using crystaldiskinfo.
