Sexual Chocolate
- Feb 25, 2003
This started as a side conversation on AVS but I needed some dedicated input on it.
I built a media server this week (Im proud so you can see pics here) and Im having some OS dilemmas.
I started out by grabbing Server 2008 32bit. There was a beta driver for the Areca card on their site. I was getting lockups every time I started file transfer or doing anything that accessed the NIC/HD (roughly every few minutes would hard lock the server). I assumed it was the cheap $17 Realtek NIC I bought so I yanked it out and put in an Intel NIC. It ran for a few hours and I copied about 1TB of data to the server and finally had a lock up last night. I think the issue is either driver related to the Areca or to some other piece of hardware. I was considering changing OS to Vista 64 or XP 64 but each of them seem to have snags. Im even strongly considering trying out Linux.
Anyway, this "media server" currently does 3 things (and I dont see this changing).
1. File Serving: I have roughly 3TB of FLAC files and 2TB of Mpeg2 rips direct from DVD. I have 4 other desktops and a laptop in the house. One of the desktops is a HTPC that needs seamless access to the movies/music. The other PC's need access as well but just for general file storing (my wifes pics/videos, my sons school work, etc).
2. Tversity: I use Tversity to transcode my movies on the fly to a format compatible with my HR-20 direcTV boxes. The boxes are basically limited media extenders and need a uPNP server running in order to connect.
3. h.264 transcoding: I use AutoMKV (essentially meGUI) to transcode my mpeg2 rips to h.264/AAC. The machine isnt beefy so it takes a few hours to transcode each movie. It requires things like ffdshow, x264, etc etc.
Thats it. Once the h.264 transcoding is done in a few months I dont even plan to keep a monitor hooked to the machine. All my data is stored on a hardware RAID6 using LBA-64bit so I need to be able to read that array.
The driver support for Vista64 seems better for my hardware than x64 (For example Areca has a Storport Vista64 driver but only a Scsiport x64 driver) and apparently Vista uses a newer samba stack and its networking/file sharing is quicker.
x64 however has a smaller footprint and file sharing is definitely simpler since most of my clients are all XP. The machine isnt beefy so the less the OS requires of my gear the better.
Then there is linux... which Im scared to death of and Im pretty sure my transcoding software wont work on it, but everyone talks about how fast it is and how simple it is to create file shares.
Anyway, I know there isnt a best answer but its a Friday and I need good discussion to keep my mind off work
