These are the best choices. Mplayer, once you learn, will work on just about any system even using other operating systems (and, btw, there are GUIs for mplayer and it supports a built-in one, though I think the built-in GUI doesn't work in windows -- yet, it WILL in the next major version coming out soon.) Media Player Classic has the advantage of being a nice simple and clean player implementing all the features that were actually good in Windows Media Player before it turned into a bloated resource hog with flashy skins to please the masses. Mplayer has the advantage of not using DirectShow (builtin decompressors) and extreme efficiency, but, is admittedly a lot less user friendly.BillLeeLee said:I vote for Media Player Classic with ffdShow filters, or mplayer which I run from the command line.
Please don't recommend codec packs. I'd even offer to pay you to not do so if I had anything to pay with (if you pay the shipping costs, I have a few pennies I can send.) The problem is, codec packs cause all sorts of troubles with conflicts and grabbed fourcc codes.korpse said:or as part of the k-lite mega codec pack: http://fileforum.betanews.com/detail/KLite_Mega_Codec_Pack/1080441198/1
