Media Center PC Questions
cillic
I'm putting together a Media PC and I'm wondering how much of my budged I should bother putting into audio.
Background: I'm getting rid of cable television so this will be my primary source for movies. I currently just have a 3.1 audio system going through a 5 year old Sony Amp/Receiver. Since we never listen to the radio, I was thinking about ditching that setup altogether and just going direct from the PC for audio (using PC speakers instead of my current setup). I live in an appartment which has no good place to make a nice media room, so I'm not worried about having ridiculous sound. My total budget is $2k.
The Beast (So Far):
CASE: OrigenAE X15e HTPC Case w/TFT Touchscreen and IR Module, Black ($599)
<<OR>>
Zalman HD160 HTPC Enclosure, Black ($259)
MB: ASUS M2N-SLI Deluxe Socket AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard - Retail ($145)
CPU: AMD Athlon 64 X2 3800+ Windsor 2000MHz HT Socket AM2 Dual Core Processor Model ADA3800IAA5CU - Retail ($169)
PS: Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply - Retail ($80)
VC: XFX PV-T73G-UDF3 Geforce 7600GT 256MB GDDR3 PCI Express x16 Video Card - Retail ($174)
BOOT DRIVE: Seagate Barracuda 7200.9 ST3808110AS 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM ($48)
STORAGE: (3x) Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM ($99 each)
DVD: SAMSUNG 16X DVD±R DVD Burner With 5X DVD-RAM Write and LightScribe Black ATA/ATAPI Model SH-S162L/BEBN - OEM ($40)
Questions:
1a) Do I bother getting a soundcard? The onboard sound should be able to fullfill my needs, and the sytem is overkill enought that I should be able to encode and watch at the same time.
1b) If so, what? My buddy is suggesting the Creative SoundBlaster X-Fi Fatal1ty FPS which has an $80 rebate, making it $120 a/r from zipzoomfly. This just seems like WAY more than I will need. True/False?
2) If I ditch my current stereo setup, does that change the answers to 1a/b?
3) If I ditch my current stereo setup, are there any current 5.1 pc speaker rigs that acutally use speaker cable so I can run cables around my room properly?
Sorry if any of these are dumb questions. This is my first forray into the media pc market.
IMO if you are going to ditch the stereo setup then there is no need to worry about a nice soundcard. If you think in the future you will need one then just get one when it is needed. Most onboard sound now is really not all that bad, with some even having optical/spdif out on them for digital audio. As for an answer to #3 if you dont listen to the radio then why not get something like the Logitech Z5500 digital speakers. If you have optical out on your onboard sound that will work great with those, if not that may be a reason to then get a sound card. I have the Logitech speakers and I really like them. I dont listen to radio either, I just have them hooked up to my 360 and digital cable. They are really cheap for what you are getting and sound great for the price, you are sure to piss people off if you turn them up.
