Frozen8950
- May 30, 2003
tl;dr Good media cabinet company that makes good quality equipment to make my stuff look its best and function its best.
Its inside a closet so muffling the sound isn't required but probably would be a nice benefit...
I have just set up my theater upstairs and I have quite a bit of equipment just sitting in my closet.
Its time for a cabinet to make it all nice and pretty.
Right now I really only have 1 rack mountable thing and its the switch.
Things not pictured are the Denon receiver and Apple TV, FireTv, Router
I also will be adding 1 or 2 rack mount battery backups and a rack mounted pc so I can play around and explore running a PC through the projector.
The space in the room is
45 inches wide,
71 inches deep
77 inches high at its lowest point (the ceiling stants down from door (highest part) to back wall (lowest part)
Im thinking I can get 1 nice rack enclosure on the right side next to the white box (there is about 38 inches width between wall and box)
So thats my current setup. Id like something tall so I can fill it up instead of bying only what I need now and having to buy another later because I maxed out the first one.
45 inches wide,
71 inches deep
