RancidWAnnaRIot
EspantaPajaros
- Feb 19, 2004
I don't have massive experience with multimeters. So i just want to make sure i'm doing this right (i don't want to get electricuted).
If i want to check the voltages on the molex connectors what i would do is set my multimeter to VDC (starting at highest voltage rating and then work my way down) and then put the black probe into the molex slot that has a black wire, and then the red probe into say the red wire. then i should get a reading of 5V no? and then for the yellow wire i shouold get 15V? is this correct.
Also say i put the red probe into the gnd and the black on the red wire, i would get -5V correct?
Are there any safety measures i have to take?
thanks
thanks
