Measuring MOBO power consumption
Saa|3
Hello, I've got a system that I want to install in my car eventually, and I need to find out how powerful of a power supply I need. So I have my system using a regular power supply right now, and I want to measure how much power it's using right now. Is there any guides out there that can tell me where I put the leads of my DMM to measure Power? Or amperage, if need be? I want to measure it on the DC side of the power supply, not what's coming out of the outlet. I'll evetually want to measure my HD power consumption too, but I'll worry about that later.
I tried looking for power specs for some of my components, but can't find all of them. So I wanna do a real measurement to be sure, testing it under actual operating conditions. Here's what I will have in my system:
PII 300MHz underclocked to 200MHz (only because I can't post at 300)
1x 256MB PC100 RAM
PC Partner Slot 1 MOBO, built in sound
WD 40GB 7200RPM HD
Wireless LAN PCI Card
USB LCD Screen
USB Mini Keyboard.
Thanks for all the help!
Saa|3
Well this is a first, not even an attempt at a response, maybe I posted in the wrong sections? Maybe the Power Supply section would have been more useful...
But basically I found the answer myself: if you want to measure power, you need to measure the current going through a line.
The cheap way to do this is to use a multimeter, and actually cut through the line and put the ammeter in series with the line. Then knowing the voltage of the line you can calculate power.
The easy way to do it is buying a clamp meter that measures the current going through a wire just by putting it into a closed loop.
So you then measure the current through all your wires coming into your Mobo from the ATX connector, and similarly with any hard drives, etc.
So there, if someone's looking for the same thing and are smart enough to use the search function, maybe they'll find this.
Saa|3
