ME: Reset skill points?
timme
Hello,
I was playing Mass Effect for a few days this week, great game so far. Although, I wasted a lot of skill points due to my own stupidity (e.g. raising charm + intimidate both at the same time etc.) and the auto-level function for squad members.
Is there any way to reset the skill points for my character/my squad? By console command maybe? I'm not that far into the game yet, but it's annoying to know I could do better if I spent the points differently ;)
Thanks a lot in advance.
There are console commands to add more skill points. You have to edit an .ini file somewhere in order to enable the console and then you'll need the right command as well.
That's more I would need actually. In Neverwinter Nights you could set your XP to 0 and then set it to the old value again to be able to assign all the skill points again.
I guess I'll have to study the console commands a bit closer then :)
