cellophane-noodles
- Aug 4, 2006
So, I had just download pskill. And I decided to test it. I started closing the svchost processes using the regular task manager. (There are like 4, you know, and you can kill the first three but not the last.) So I had killed like 1, and then the second one I killed gave some error, some process had been unexpectedly terminated. A popup box counted down from 60 till the system restarted. Well, I checked what process it was. it was winlogon.exe. So I was like, I'll just kill it with pskill, let's see if it works. And it killed it. Then I got a bsod (I couldn't read what it said, but that's a seperate issue.) So then I was like, whatever, I'll just restart. And everything went fine, right through selected the user. Then it just hangs, showing the background, all processes normally loaded. Except if I go and see which user the processes are run under, they all have a blank there, including the SYSTEM processes. So for some reason winlogon is not correctly logging on the user. Safe mode does work, fortunately, but system restore did nothing. Help me! This isn't even my computer (it's my parents), and I need to fix it asap.
thanks!
thanks!
