I'm planning on upgrading my current NAS to ZFS. You can find my current build, aswell as some of the specs of my future build here.
I'm thinking now would be the ideal time to switch to ZFS, since I have a 4TB external drive where I can transfer all my current data which happpens to be around 4TB (3x2TB in RAID5 via mdadm). I'm still pretty clueless when it comes to the mobo, cpu & controller and could definately use some advice in that departement.
I'm also thinking about only buying one extra 2 TB drive for the moment, and invest in the core of my new ZFS build and when the time is right I can purchase an additonal controller and more hard drives.
Expanding your array in ZFS however doesn't seem to be as painless as it was in mdadm. Would it be wise to operate like this, or should I wait it out a little bit longer so I can save up a bit more and can all my drives at once?
Controller-wise, I've been looking at a lot of cards. IBM M1015's seem to be really popular, but I don't really like the placement of the 2 ports since they are pointing upwards and would result into poor cable management. I mentioned a few alternatives in the excel doc (at the top), but I'm not planning on spending too much on a controller since its only purpose is adding more slots (from a ZFS pov). I do however want a controller which has SAS 8087 slots, as I'm planning on connecting them via an internal 8087-to-8087 cable to improve cable management.
Thanks in advance
Thanks in advance
