Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Swiftech make a kit with a 120x2 radiator but its kinda ghey. I'd go with the H20-120 rev2 kit or just build your own.The Black Ice Extreme 2 or 3 (2 120's and 3 120's respecitvely) are good rads for use with that waterblock.
Just get a Heatercore from your auto parts store, got my Caprire dual 120mm fan core for about 20$, cut the barbs down, and force the tuding over it. Make sure you go 1/2 and not 3/8. If you need help slipping it over, boil the tube in hot water. Also kits are nice, but DIY is much better and cheaper. PM or post back in this thread if you need some help. Also read thr stickes at ocforums.com lots of good info their.
