MCW60 on a GTX970
THRESHIN
yeah i have some older WC equipment...hell my entire rig is getting very old.
anyways looking to upgrade with the black friday sales. wondering if anyone knows if my old equipment will fit new hardware? yes i've searched google without much luck.
planning on getting either a nvidia GTX 970 or ATI R9 390...and my GPU block is a swiftech MCW60....anyone know if this will fit? i do have the old G80 adapter kit around here somewhere....i do have a bunch of copper ram sinks that i can use for the memory and any other components that might get a little too warm.
for CPU i'm planning on going LGA1151. probably an i5 6600k. the CPU block i have is a swiftech apogee GT.
any thoughts?
thanks!
Thought I'd answer since it's not that old, but for it to work you just have to shorten all of the plastic spacers a bit and it fits perfectly.
