MCR320-QP Question
soulesschild
When swiftech's website says the MCR320 is compatible with G1/4" threads, my BitsPower G 1/4th compression fittings should fit with no problem correct? If so, why does BitsPower sell a 1/4 NPSM to G 1/4th transfer adapter????
Because, iirc, Swiftech's radiators used to use the NPSM threading, as did (some still do) other US made radiators. So if you are buying a radiator used that is a couple of years old, it could use the 1/4 NPSM threads.
