mcp655 primochill myriad combo
Modder man
I have had nothing but problems with these two. I have it running currently but the pump is terrible loud, it seems to be continually sucking air through the loop. The air does not seem to be settling out.
Not really sure what to do with this, I think if I could slow down the pump it would help but I am hoping there is an alternative?
What sort of reservoir do you have?
And yes, you should be slowing down the pump to get the bubbles out. This is pretty much a requirement for bleeding a loop.
