MCP655/D5 Noise Level
maeveth
What should a D5 sound like? I just finished my install and everything works however the waffles back and forth between two sound levels, sometimes its very quiet other times i get almost a rattling noise from it. I can confirm that its not due to any vibration with the pump mounting or any lose fittings.
I am using the Bitspower top for it.
Is it normal for it to sometimes make too more noise?
yeah, I barely hear mine. Air takes a while to get out though.
You use distilled water, right?
