MCP350 to Primochill Ghost Compression.
hanipman
I'm stumped. I've done as much research as I can tolerate, but I can't seem to figure out the best way to go from the 3/8" MCP350 outlets to a G1/4 Female thread for the Primochill Ghost compression. Someone care to enlighten me?
And incase it wasn't obvious I'm trying out Primochills rigid tubing: 3/8" ID, 1/2 OD.
If you are talking about the stock top with the 3/8 barbs, it will not work with out using some normal tubing.
The best solution would be to replace the top. Here are a couple of examples.
http://www.performance-pcs.com/cata...oduct_info&cPath=59_439_769&products_id=22700
http://www.performance-pcs.com/cata...roduct_info&cPath=59_439_771&products_id=4506
http://www.performance-pcs.com/cata...oduct_info&cPath=59_439_774&products_id=26992
http://www.performance-pcs.com/cata...oduct_info&cPath=59_439_769&products_id=23357
There is other tops from other manufacturers but this should at least get you started.
Thank you. Honestly, the only way I could have seen it working was if I started with normal tubing and then used an adapter, but it would be both ugly and a bit unstable. I guess I'll just settle with the cheapest top I could find then.
This is the best solution.
