So I have two questions. First, some background info to provide details.
I run a two hard drive system. A 320GB hard drive for OS's and programs
and a 1TB hard drive for all Data. Somehow, Windows 7 has installed a boot loader to
each drive. I know this from Grub2 auto searching for bootloaders.
Now question 1) In the past couple of weeks, Windows 7 has frozen video
and visible input, the OS keeps running for a while (i can hear the movie
being played still) but as far as the eye can tell, all computing has stopped.
Eventually, I get a blue screen that gets rebooted before i can read any of it.
After said reboot, I get a Windows Boot manager has failed ( can't find its target OS).
I know this is the bootloader from the Data drive, as Grub is installed on the OS drive.
Upon further inspection, I notice that the OS drive isn't being detected by the Motherboard.
But whenever I boot from a LiveCD, I have no issue mounting the OS drive.
I'm fairly certain the drive isn't dying as chckdisk is not reporting any errors
it needed to fix. It's as if this freeze simply deleted my MBR. But that doesn't seem
quite right either, as even after I re-install Grub, the drive isn't detected at first.
After I change which ports the Sata cables are plugged into on the motherboard do
I easily boot into the OS of my choice. I, first went from ports Sata1 and Sata2 to
Sata3 and Sata6, and now I am back on the original Sata1 and Sata3. My knowledge
of computers is flaky when it comes to Sata controllers. Is there some kind of memory on the
Mobo that remembers what drive is where after a reboot, and my changing the plugs
forces it to re-search what drive is where?
To be fair, my sample size is rather small. This freeze, followed by the same
exact events, has only happened twice. But it feels like the Sata controller is going faulty.
Question 2 is my simply asking if I can somehow remove the Bootloader from the Data drive.
It is honestly annoying when I expect to see Grub and a windows bootloader has shown up.
