MBP Expose
aaronearles
I love expose, but I hate that I have to hit Fn to access it, what keys do you guys use on your mac notebooks to activate expose?
I leave it so that I don't have to hit FN for expose, but I do have to for the F key function.
why don't you change it? :confused: you can choose whatever key you want to use to activate it. Default is F9-F11.
I use the screen corners.
Move mouse to top right for "all windows"
Bottom right is "Desktop"
and Bottom left is Dashboard.
Yeah I know you can change it, but f9 and f10 are used to light the keyboard, so it really drives me crazy, just curious to see if anyone had a really good setup for it. I like the F keys to adjust the volume and brightness without the Fn Key, I guess it's just preference, oh well.
On my Macbook, I just use the F3 button (Default with Expose Icon) to further clarify my earlier post.
Same here
Corners is much easier and productive than using KB shortcuts.
The hot corners are definitely the best way to go about it because it becomes very natural. Dragging stuff into different folders/onto the desktop and so on is one of the main things that impresses me about the OSX gui over standard Windows.
