MBM5 or Sandra for temp!?
Shogo
Ok well... .in mbm5 my p3 800mhz shows to be at 72celcius on full load (wtf)
in sandra, it shows 40celcius.
Wich one i should trust?
Use Speedfan and see which temp you get. Probably the higher temp might be the correct one.
Yeah, get Speedfan or another monitoring program and see if you can figure it out...
