Mbm?
Wreckless_Process
how do i turn it on so i can view my cpu temps and stuff. i have a program to do it(samurize) but idk hwo to turn it on
just fire up the program. a little box should come up with a drop down menu asking you which motherboard you have, then a couple other config things, like which fans/temps to monitor, etc. you can probably leave these at default. when you start the program (after install) it will only come up on your task bar. probably as a 2 digit number, which will probably be your cpu temp. click on this, and then click on dashboard(i think this is what its called) this will display your stuff and let you customize the display. its been a little while since i used it, but this is pretty much how it goes. if you have some program that came with your mainboard, try that. if you are having trouble with that, please explain in detail.
good luck.
