So, based on some fiddling around with mbm5, I was able to get my cpu diode sensor to "work". However, it appears that at least on my asus a7n8x with a barton 2500+@3200+, the diode isn't good for much. At idle, the socket read 32, diode read 38, I thought sure, could be true. I started up prime95, and within *seconds*(like, 2 or 3) diode temp shot up to around 48'C, and is bouncing around all over between 46 and 49. Does this sensor actually work at all? The socket temp sensor slowly but steadily rises when I run prime95, usually up to about 38'C, but the diode is jumping all over, and not staying consistent at all with the socket temp sensor. Does this make sense?
Upon exiting prime95, the "diode temp" dropped right back down to 40. The diode temp seems to be nearly 100% dependant on cpu load, and nothing else. IE, if the cpu load goes up to 20%, the diode temp will rise. If the cpu load is sitting at 0, the diode temp will sit around 38'/39'. At 100, it sits at 49. Is this normal?
