MBM 5 and CPU Diode readings...
homIcIde
When i use MBM5 i get 3 temperature readings, case, cpu socket, and cpu diode. the diode temperature is always noticeably higher than the socket temperature. However, i have no idea where this diode reading is coming from. I have also taken measurements from my bios and from Asus utility, which only give me the case reading and a cpu reading that matches up with MBMs socket reading. Where is it coming up with the diode reading? Should i trust this and base things off of the diode reading for the socket reading which corresponds with the other cpu temps im finding?
