MB vs ram
speedlever
I have an Asus P5B-E rev 1.01g mobo that I built last year with 2x1 Gb Corsair TWIN2X2048-6400C4 (PC2-6400).
http://tinyurl.com/yoaf2g
I just ordered some additional RAM: Adata 2x2GB PC2-6400 ram:
http://tinyurl.com/2opv83
It appears that the Corsair has a CAS latency of 4 and the Adata has a CAS latency of 5. Will this pose a problem if I use all the RAM for 6 GB total?
I am running stock settings in the BIOS. I never had much luck OC'ing this setup past about 350 fsb as I recall. Haven't messed with it in a long time.
Also, I'm a little confused about the dual channel part. I thought the channels were represented by the different color sockets... ie, yellow sockets are one channel and the black sockets are another channel. The user guide for the P5B-E shows (page 2-13) that Channel A is DimmA1 and A2... which are the first yellow/black group and Channel B is DimmB1 and B2 which are the second yellow/black group.
Is this an error on the part of the guide or am I misunderstanding what it's telling me?
System:
P5B-E
e6600
76b Raptor sata
320Gb Samsung sata
300 Gb Seagate ide
2x optical drives
Vista/64 bit
other goodies
You should not have a problem, just run all your modules at the speed of the lowest common denominator.
You are right about colored modules. In order for dual channel to work the pairs of modules need to be on different channels. It's like a striped array. The system talks to the memory using two channels instead of just one.
So you pair together A1 and B1 to get double the bandwidth by using both channels to talk to the same amount of memory.
If you used A1 and A2, you would be using only the single channel to talk to your memory.
I would stick the larger kit, the 4GB kit on A1 and B1, and your older 2GB kit on A2 and B2, and then manually set the timings for the lower rate. Then again, the lower memory may work at the tighter timings. Who knows til you try and maybe run some memtest86+.
Typically, when you populate all 4 dimm slots, I have heard many people talking about it limiting overclocks.
Your corsair is rated at 2.1v and the adata is rated at 1.8...-
not good.
not good.
Should not be an issue. If your not overclocking, running them at the default DDR2 voltage spec of 1.8V should be no issue. Running DDR2-800 at V1.8 should be no sweat for any module.
The corsair are specced for upto 2.1V, but they will run fine at 1.8, I run my 4x1GB XMS2 set at 1.8 with no issues.
Most all DDR2 modules will safetly take 1.8-2.1V or even a little more maybe if your trying to push their clock speed hard.
Thanks guys. I appreciate the info.
We'll see how it shakes out. (once I sort out the failed BIOS update I just did).
Edit:
Update... fixed the BIOS update problem by taking out the CMOS battery. Had to try to remember all my BIOS settings (which had also been a long time since I tweaked). It works, so I must have done something right.
Took the opportunity to move the current ram to the B slots in preparation for the new ram.
Update: received the new ram today. Installed in channel A. In BIOS I have the ram set to 533, left SPD in auto but changed the ram voltage from Auto to 1.8.
It seems to run just fine. However, my Windows experience dropped from 5.6 to 5.2. Could be me, but everything seems to run snappier with 6 Gb ram vs the old 2 Gb ram. Shrug.
I beleive it.
Windows experience does a bandwidth benchmark, so like sisoft or other synthetic benchmarks it would drop. Memory bandwidth is surprisingly in real world applications not all that critical (to some extent), especially not as important as having enough.
Interesting about the bandwidth vs WE rating.
One other interesting thing I observed is that on boot-up, I see 50xx Mb ram recognized. But Vista/64 sees all 6 Gb just fine. So maybe that boot-up ram msg is flashing by too quickly for me to read what it really says.
