MB Suggestion
Nexrus
I've heard every good build starts with a good MB so I was hoping you guys could help me pick a motherboard since I'm new at this (i've been browsing mb's and reviews for hours and I'm still lost)
First of all my budget is 150$... I'd really like to keep it close to 100 if possible, but of course I would like something thats not going to be dead within a few months
I plan on having
4gb's ddr2
dual or quad core processor (lga 775)
atleast 2x sata ports
1x pcie card (I dont plan on ever using sli or crossfire)
I hope this is enough info. Thanks in advance.
It depends on what kind of build you are doing. I'd go for a P35 chipset based solution if money is a concern. DFI ASUS ABIT MSI GIGABYTE all make solid P35 boards that have tons of BIOS adjustments. If you don't need the tweakability go with an INTEL or ASROCK, which may even be cheaper. Be careful about getting a 45nm Processor on a P35 too, not all boards support it, and some need BIOS updates to run them.
For an overclocking system, you should ask someone else here, but I'm pretty happy with my ASUS PK5-E.
If you aren't going to be overclocking then I would recommend the P43 chipset over the P35 as it was designed specifically for the Penryn processors and runs much cooler then P35. If you plan on doing some decent overclocking then I would move up to the P45. Here are some boards you could look at in your price range.
P43 Boards:
GIGABYTE GA-EP43-DS3L - $98.96
ASUS P5QL PRO - $98.96
BIOSTAR TP43HP - $99.38 after $10 MIR
P45 Boards:
BIOSTAR TForce TP45HP - $119.38
GIGABYTE GA-EP45-DS3R - $119.38 after $20 MIR
ASUS P5Q Pro - $139.99
