Maze4GPU vs. Swifty for X850XT
Kil4Thril
I'll be using a 3/8" system with the DDC/MC350 pump. Which of these will give me better temps, or will it be so close as to not matter? It will be in a loop with a BIX2 (or 2 BIX's- haven't got the case yet) and probably a Swifty block on the CPU. Go easy on me, this is my first H2O cooler.
either or really, The silverprop fusion HL is the best gpu only cooler. It has natively 1/2" barbs but you can stretch 3/8" tubing over 1/2" pretty easy.
I'll check into the Silverprop, and maybe I'll just run 1/2" system instead. Everything I've looked at is available in that configuration anyway. Thanks for the reply.
the only downside about he silverprop is that you have to wait a couple weeks to get it. Other then that its good. I personally didnt want to wait and ordered the maz4gpu with brass top and it works great for me. You also would need (well highly recommended) that you get some ramsinks. I have some OCZ BGA copper sinks. There are other sinks but most people around would recommend the OCZ kind
The maze 4 with the delrin is probably the better option. Durability and corrosion resistance is great, plus you dont have to worry as much about weight.
Sivlerprop if using MCW600x block. If using restrictive CPU block use DD Maze4.
