maze4 or spir@l?
kronchev
well right now in my possession I have a maze4 block, and a spir@l block. which one perfoms better? i have the maze4 in my system and right now, 2400+-M at 2.4 ghz, I have 32 idle, 35 load, with an ambient of ~25C. this is with a chevette heatercore, I have a dual bonneville that just needs to be barbed and then will be put in. but if the spir@l can perform better than the Maze4 then I will switch out.
i'd try it and see, but i'd put my money on the maze 4 personally. can't hurt to try (unless you really screw up mounting it)
thats what im afraid of. i hate mounting blocks. hate it hate it. plus I just took down my system, tried to cram a heatercore in my case, had the connections leak all the fuck over, and had to put it back together wtih the old core, so i'm really not in the mood to drain and refill all again, esp when I'm getting very good temps as it sits right now.
i probabily will end up selling this to my friend, or possibly keeping it for WC for my future backup comp
the Spir@l, higher flow rates,
then break out the drill press and "dimple" the base and help it out some :)
hmm...I wish I was that [H]ard :D
im gonna look into rigging up some P4 goodness at a minimum expense
oh come on man I dimpled my TC-4 Rev2 :)
