Maze4 on X800 Pro
Silent Assasin
So uh, someone told me that the fittings for a 6800GT on the maze4 would work with my x800. Yet after receiving my maze4 with my 6800GT fittings, it's not right at all.....
Anyone know if any of the fittings for the maze4 will work??? When I alligned it up with my card, it looks like the 2 holes on the side (through the copper block) would work. They are threaded holes but does DD sell the correct mountings for this? I have the low profile acetal if that makes any differance.....
Just email Danger Den and let them know what type of card you have and they will send you the hardware. The 2 holes are the ones for a ATI card and they are theraded for 4-40 screws if I remember right. You'll need 2 screws, 4 nylon washers and 2 springs. Danger Den might not even charge you for them, they never charged me for little odds and ends that I either lost or whatever.................... :eek:
