MAZE4 gpu on x1800 series
Silent Assasin
Just out of curiosity, would anyone happen to know if the Maze4 will fit on the new generation of cards by ATi? I noticed that they switched over from the 2 hole to the 4 hole mounting hardware. It almost looks the same as the Nvidia mountings but then again, I'm only going from pics from Newegg. In my case build, I'm leaning toards building a new rig even so I'm looking into my options as far as SLI and just starting to look into the ATI flavor of SLI. I would also like to keep all of my water gear and just move it.
i know the Zalman vf700 still fits on the x1800 series, so i dont see why the maze4 wouldnt.
it fits with the nvidia hardware.....so when you order it order the nvidia kit, so you will get the 4 screws, which by the way are thicker than the ones use for ati hardware..l..
